car wont start after sensor mix up
Old Jun 5, 2017 | 04:31 AM
cityofcaterpillars's Avatar
Default car wont start after sensor mix up
turbo d16z6 in eg
I accidentally plugged the MAP sensor plug into the TPS. So the TPS plug was not plugged in at all. I also have a 3 bar MAP which is wired into the harness. The car would die at anything over tiny throttle inputs. I immediately pulled the car over and plugged everything in right but now the car wont start. No CEL. Hondata when is gauge display mode goes nuts and throws random numbers. I looked at the ECU and nothing looks burnt.
Im not really sure where to go from here. I'm gonna swap the TPS after work and test a different ECU.
Any suggestions on top of that would be awesome.
Old Jun 5, 2017 | 06:20 AM
mk378's Avatar
Default Re: car wont start after sensor mix up
Check the ground wires. Check for 5 volts supplied from the ECU to the MAP and TPS.
Old Jun 5, 2017 | 07:12 AM
It's not a ground because there is still power to everything. I will check for power to TPS
Old Jun 5, 2017 | 11:56 AM
NotARaCist's Avatar
I never narc'd on nobody!
Not necessarily true. When you turn the key to ON(II), does the CEL come on for ~3 seconds then turn off? Does the car try to start but not catch, or does it not even try to start?
Old Jun 6, 2017 | 08:20 AM
well after swapping on 3 different TPS and 2 throttle bodies it turns out that my brand new Motorola 2.5 bar map went bad. plugged the old map in and it runs fine. I emailed xenocron where I bought the MAP sensor and unfortunately they wont refund or exchange. But bright side the car runs again.
Old Jun 6, 2017 | 12:45 PM
mk378's Avatar
There's never any warranty on racing parts.
Of course, you need a different tune for a stock MAP vs. extended range.
Old Jun 7, 2017 | 03:13 AM
it was tuned for the 2.5 bar. Oh well I'm gonna go with a hondata or omni map like I should've in the first place
mdb4879
Jul 1, 2019 12:33 AM
trippsEF9
Apr 3, 2013 11:08 AM
SiR18EG
Nov 6, 2008 02:06 PM
Rukusmasta2
Jul 26, 2008 01:16 AM
