1997 Honda Accord EX Speedometer Trouble
Hey guys. I've had a 97 Accord (Vtec) with a speedo+odometer that hasn't worked for the whole year I've owned it. The previous owner said it was just a bad speed sensor, but he failed to mention he had an antifreeze leak that completely burnt the wires to the speed sensor plug. I've replaced the speed sensor and plug, spliced new wires, checked that everything has power from the sensor to the cluster, the sensor pin spins like it should in the transmission, no check light code, and used 3 different clusters where all gauges and lights work except the speedo+odometer. I've cleared the codes and have left the battery disconnected for a while several times. I've searched all over for different answers/tricks, but nothing seems to work. Does anyone know what could be the problem? Sorry for the long post, but I'm about ready to give up. It's my first time posting here and I want to make sure I put all the details in. Thank you so much for reading!
willela12
Sep 17, 2017 04:14 PM
