How to test an ECU for VTEC Engagement
Old Jun 3, 2017 | 08:53 AM
pleej's Avatar
Default How to test an ECU for VTEC Engagement
Witch ports do I use to test contest vtec
Old Jun 23, 2017 | 08:11 AM
Roy Leyva's Avatar
Default re: How to test an ECU for VTEC Engagement
Put a light bulb at A4 and to a ground, go to drive and hit 5500rpm, if light goes on then vtec is engaging, if not then you can send to me for free that ecu XD
Old Jul 7, 2017 | 07:16 AM
Sir001's Avatar
How does if a4 always have voltage if running below 5500rpm? What's wrong with it?
Old Jul 7, 2017 | 07:59 AM
Roy Leyva's Avatar
Wrong, A4 only send voltage to selenoid when vtec engages, so if you can put a light to see if ecu are sending voltage
Old Jul 8, 2017 | 09:12 AM
7rrivera7's Avatar
Default Re: How to test an ECU for VTEC Engagement
Light bulb? Perhaps a 12v LED would work...
Old Jul 10, 2017 | 06:51 AM
Roy Leyva's Avatar
Old Jul 13, 2017 | 05:17 AM
h1tman's Avatar
Put light bulb. It will imitate a VTEC coil.
bmxmacdaddy
Feb 28, 2009 01:49 PM
jdmwannabe3
25
Apr 14, 2006 08:57 PM
GTEC913
Mar 11, 2006 03:46 AM
m3dia_lab
Aug 1, 2003 10:14 AM
h22 civic
Jul 28, 2003 05:36 PM
