crack in rear subframe,pics attached
Hello guys,
Ive been having a civic type r rear sway bar on on my 00 si since 4 years and just discovered that there is a crack in the subframe.
i was wondering i fit it is safe to weld it and drive the car (probably well put back the stock sway bar)or what should i do ?
That part is replaceable on the car requires some spot weld drilling and welding a new piece replaced those on one of my si a long time a go you can get that piece off any Civic that same body style and if some tells you the car is junk don't listen to them
It's not that bad of a job just takes sometime and some tools just remove the old under coating from it i think there's like 20 spot welds on it our maybe less it's been sometime since i did that job a welder and some basic welding skills and it done you will have to drop the fuel tank
SoullessJapaneseMachine
Honda Civic (2006 - 2015)
17
Nov 26, 2007 05:05 PM
MonkeyPuzzle
Mar 20, 2007 09:19 PM
