Transmission & Drivetrain Gearboxes, Differentials, Clutches
Civic awd system power limit?
Old May 22, 2017 | 10:08 PM
eg:R's Avatar
Default Civic awd system power limit?
Thinking about doing this awd project to my eg gsr turbo. What is the power limit to this awd system stock? Or can you built the transfer case and rear end? Which is better crv or civic wagon rear diff ? Can these stock awd system handle up to 500whp.
Old May 23, 2017 | 01:31 AM
Balor_Gr's Avatar
Default Re: Civic awd system power limit?
Id like to know too its getting very cheap to do it nowadays in europe when everyone sells their whole CRV for 800-1000 euro.
Old May 23, 2017 | 03:46 PM
GoldieWang's Avatar
10 Year Member
the wagovan rt4wd system from what I have researched is pushing the limits at 500whp depending on the torque and not launching the car. but really its usually the transfer case that fails first which may be good as crv transfer cases seem easier to find than the rt4wd components.
Old May 25, 2017 | 05:47 PM
motoxxxman's Avatar
I recently finished building and tuning a d16z6 410hp awd wagovan. first time shifting hard to 2nd, the u-joints snapped. Had a custom driveshaft made with truck ujoints, everything has held up great since. 225/50/15 dunlop direzza tires all around, super sticky.
Old May 26, 2017 | 09:13 AM
bigG's Avatar
I am working on one myself. With that said, i dont think with todays tires and ecu management its needed for under 500whp on the street.
Old May 26, 2017 | 06:55 PM
motoxxxman's Avatar
um, yes even with today's technology there is a huge difference in traction with awd vs fwd, especially on the street. It's a fairly well known fact that anything over 400hp is pretty useless on the street with fwd under 75mph lol. I personally can spin 3rd gear from a 70 roll on a colder day like clockwork [with lsd and sticky 17" street tires]
Old May 27, 2017 | 09:27 AM
G-power's Avatar
I have my 88 wagon turbo rt4wd d16z6 400hp no problem
Old May 27, 2017 | 09:30 AM
bigG's Avatar
Then your not using todays technology. A motec system with bbg traction control and decent drag radials will easily hold 400whp fwd car.
Old May 27, 2017 | 08:30 PM
motoxxxman's Avatar
I guess you've never launched a fwd and awd car from a dig side by side before to see how drastic of a difference there is at 400hp on drag radials or sticky street tires. no matter how good technology gets, traction is only as good as traction. front wheels pulling the car vs all 4 tires pulling the car is a HUGE difference in traction, and rate of acceleration.
Old May 28, 2017 | 02:18 AM
G-power's Avatar
4wd to 2wd Never compare friend for 4wd only street tires launched easy . I much try street drag
For 2wd difficult
Old Jun 3, 2017 | 03:21 PM
bigG's Avatar
im not talking about street racing fyi, im talking about a 400whp daily driver. If you are looking to get every bit of power down at that level why would you be using street tires. also he will be breaking that transfercase if he is planning to launch on the street . we are not talking about a evo or gtr here.
Old Jun 4, 2017 | 08:56 PM
motoxxxman's Avatar
you're somewhat contradicting yourself here. a daily driver pretty much NEEDS to be on street tires. so I'm a little confused what your point is.
also, breaking the transfer case by launching on the street would heavily depend on how aggressively he launches the car, how pliable the tires are, and how much flex the clutch disc allows and it's pressure rating for said flex (sprung disc).
Old Jun 4, 2017 | 11:40 PM
G-power's Avatar
400whp launch for all car risk Transfercase
Old Jun 6, 2017 | 08:58 AM
backroadCR-V's Avatar
You'd do better posting this in the transmission and drivetrain section.
j_the_guy
19
Nov 23, 2018 12:42 PM
eklum
Nov 3, 2010 11:37 AM
civic scene
Audio / Security / Video
Mar 15, 2006 08:28 AM
egchan
Acura TL, RL & ZDX
Oct 13, 2004 07:22 PM
Aquafina
Acura TL, RL & ZDX
23
Aug 5, 2003 01:05 PM
