Crushed spark plug!? How!? Happened at the track.
Hey everyone.
I went to the track today to take my '93 del Sol Si for a spin. It has (or had...) a built NA d16z6. During the last Dyno tuning I made 158whp. I love this little SOHC but today something happened....
I came around a corner at the track, tried to downshift and it felt like I missed the gate. I can't recall if I over-revved the engine (I'll have to watch the video) but I heard a noise. I pulled off the track and tried to start but all I got was a CLUNK.
I had it towed home. I pulled the plugs to try to move the engine at the crank. I noticed plug #1 had what looked like some markings on the base of the plug around the electrode. Then plug #2...
Trying to take #2 was much harder than it should have been. When I finally got it out I could see that the electrode end looked entirely smashed in. I pulled the valve cover off and everything there seems ok. Doesn't look like a valve dropped (I can see all 16 shafts and the connections to the springs).
What could it have been!? Did I actually drop a valve? Valve float (I'm using the Rocket Motorsports valve springs and Ti retainers with the stage 4 re-grind camshaft)? Detonation?
The timing belt still looks good (I have the cover off to access the adjustable camshaft gear) and the camshaft gear is still sitting at 1* advanced.
I've attached pics.
Plug from cylinder 2:
Plug from cylinder 1 (much less damage but still evidence of something contacting the plug):
I've attached pics.
You have eaten a valve... or obliterated a piston. Either way, time to tear down. The plug pics you have posted indicate flying metal striking the spark plugs... the question is where did the metal come from ???
it's a high compression build using P29's and an aggressive camshaft. The block was decked and the head resurfaced during the build. The compression calculator suggested near 13:1. It was advanced only 1* but there would have been very narrow tolerances. I wonder if even the slightest amount of valve float, in spite of the springs, could have resulted in this...
mattsnooz
Jul 30, 2007 01:44 PM
arielb1
Jul 24, 2004 10:24 AM
