96 Accord tach issue
Old May 21, 2017 | 05:23 AM
Krc2705's Avatar
Default 96 Accord tach issue
So I have a 96 accord 2.2 vtec and I recently replaced the distributer (due to oil leaking into it) and now the tach is acting odd. While driving it works fine until 3k then it starts flipping between redline and 2k. I replaced the coil and still no change. I'm at a loss right now and it is really bothering me. Any help would be greatly appreciated
Old May 21, 2017 | 07:26 AM
poorman212's Avatar
Default Re: 96 Accord tach issue
The tach is driven from the ICM. Is it possible that you might have "nicked" the wire when doing the seal change?
Old May 21, 2017 | 07:29 AM
Krc2705's Avatar
I will have to look into that it's had a few other random electrical issues too
Old May 21, 2017 | 08:07 AM
poorman212's Avatar
Oh, and now that reading comprehension kicks in......you said you replaced the dist and I assumed you replaced the seal....so I might have jumped too soon.
Either way, the tach reads from the blue wire off the ICM. If the engine is running fine when the tach goes wacky I would start with checking the wire.
ChevelleSSLS6
Jan 23, 2011 11:10 AM
Mikey3000
Sep 6, 2006 02:32 PM
Fenix_Vtec
Sep 7, 2004 10:19 PM
turboH22Aakkord
May 19, 2004 09:25 AM
White LX
May 29, 2003 08:35 AM
