EF Mount Question!
If i use the stock mounts that hold the b16a in the JDM CRX Sir could i just use those to swap a b16a in my USDM 89 CRX instead of getting aftermarket mounts such as Hasport, HCP and PR???
No? I think you CAN! But, you will have to get both halves of the mount (engine side and car side), remove your stock mounts completely, and then weld on the SiR body mounts in the CORRECT location. That's how the old weld-in mount kits worked bafore these bolt-in kits came along.
you can use the stock mounts but u have to git the passenger side mount (i think) relocated and welded on to the siR position then u can use the stock mounts...IMO i think its better cause u wont have to deal with crappy asz vibration at any times...i got my swap long time ago and im happy with using the stock mounts...but make sure whoever does the welding for u has experience cause alot of people mess up
Snail Tuning
Jan 14, 2005 09:34 AM
