2002 Honda Accord Rmp jumps
Hi guys.
. I can use an advice, my 2002 honda accord rmp jumps around 2000 while driving and odometer at 60km. The car shakes but when I shut off the car and restart it goes away. Then come back after awhile. Any help would be appreciated. Thanks
Check for any stored codes - I'll guess you are in Canada, so I'm not sure if there are parts stores that will do this for free. Yes, if you have a 4 cyl, it could be the ICM but at the same time a "strange" trans issue (again assuming an auto) could mask itself in such a way that you think it is an engine issue.
Cost, well again it sounds like you are not in the US - so I can only guess. If you do it yourself the ICM is 55~60 and will take a little of you time to remove it from the dist and install the new one. One thing to think about is replacing the whole dist - yes that is a bit far out there but - for that you save the time to dismantle the old one hoping you don't mess anything else up. A new one is ~140 or so and most of them come with a new cap and rotor (not sure how old the current ones are?), new external o-ring and internal shaft seal....have any signs of oil leaks around the dist area?
Anyway I'm making some "guesses" which I shouldn't do but was just trying to offer some additional information to think about.
Would you confirm the engine size (4 or 6 cyl) and trans (auto or manual).
You will know if it's slipping or power is completely cutting off at the time the rpm is jumping. I guess when you said jump I was thinking it was going both up and down but if it's just going up and it's slipping then you will know.
Porsha Renee'
Mar 17, 2023 03:15 PM
sunstealth
Oct 18, 2004 07:14 PM
