-=-=-=-=-install SI gauges??-=-=-=-=-=
Old Nov 10, 2002 | 01:32 PM
Filliam H. Muffman's Avatar
Default -=-=-=-=-install SI gauges??-=-=-=-=-=
im gonna put SI gauges in my car...but i deno how to do the tach part...anyone wanna fill me in? 96 EK9 (EJ6) its all the same baybee
Old Nov 10, 2002 | 01:33 PM
MPower332TI's Avatar
Default Re: -=-=-=-=-install SI gauges??-=-=-=-=-= (JUN EK9)
um..u take the old one out and u plug the new one back in.. kinda complicated so take ur time. match the plugs and plug them in.
Old Nov 10, 2002 | 01:35 PM
IM ALL BOB's Avatar
IF you are putting a EM1 SI gauge cluster into a EJ6 vechile it will be plug and play ..just look at where the plugs go in on your ej6 cluster when u take them out and do the same when u put in the SI gauge cluster..5min top to put this baby in =P
Old Nov 10, 2002 | 01:37 PM
FifthGearOnline's Avatar
Default Re: -=-=-=-=-install SI gauges??-=-=-=-=-= (IM ALL BOB)
<U>1) SEARCH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!</U>
2) did i mention that this has been covered more times then you can count?
Old Nov 10, 2002 | 03:15 PM
b00stn's Avatar
Default Re: -=-=-=-=-install SI gauges??-=-=-=-=-= (FifthGearOnline.com)
I know, if people would just search they would find more info than they could possible want. Just search the archived topics and you will find tons of info on everything. If its not there, then post a new topic so people can find it later when they search.
Old Nov 10, 2002 | 04:14 PM
JDM_EK3's Avatar
Default Re: -=-=-=-=-install SI gauges??-=-=-=-=-= (b00stn)
This link will show you how to remove your stock cluster. And installing the new one is just as simple, because you do everything in reverse.
http://www.autotoys.com/New_Tech/DIY..._kit_civic.htm
Old Nov 14, 2002 | 09:46 PM
Default Re: -=-=-=-=-install SI gauges??-=-=-=-=-= (2NR)
i dont have a tach on my car...its tachless....tahts why i wanted to know
Chaser4dr
Mar 1, 2005 02:54 PM
stickyfingers
Mar 14, 2004 07:08 PM
ekb18cCivic
11
Dec 23, 2003 06:50 AM
Eibach95Civic
Mar 25, 2003 12:52 PM
Filliam H. Muffman
10
Dec 13, 2002 09:51 PM
