Help,Can I put 91 motor into a 95
Old May 18, 2017 | 05:05 AM
Big joe's Avatar
Default Help,Can I put 91 motor into a 95
Will a 91 accord motor swap into a 95 accord, both are automatics: Are any modifications needed,. wiring, mounts, etc,..?
Also are the tranny's the same? Or would Mod's be needed on it too if I do a complete swap of Motor & tranny?
Thanks for Your help, it's much appreciated
Old May 18, 2017 | 03:09 PM
holmesnmanny's Avatar
Default Re: Help,Can I put 91 motor into a 95
it will swap but you will need to be sure you're in a state where it is allowed for smog purposes, some states won't allow you to swap an older engine into a newer chassis, california is one of them
Old May 18, 2017 | 03:48 PM
Big joe's Avatar
I'm already aware of the emissions in general (which isn't a issue in TN).
My Question is " Are any modifications needed,. wiring, mounts, etc,..?
Also are the tranny's the same? Or would Mod's be needed on it too if I do a complete swap of Motor & tranny? "
From what I have read, You can swap anything BUT How much aggravation in regards to Modifications has to be made is my question.
Old May 19, 2017 | 01:03 PM
GhostAccord's Avatar
They are both OBD1 and they are both F22's of the SOHC variety. Therefore, the mounts and drive train are the same bolt-up configuration. These engines are plug and play. And as long as you have a non VTEC 1995 CD5 you will have no issues. If you have the F22B1 VTEC variation, you will require a non VTEC ECU to complement your Non VTEC 1991 F22A engine.
Old May 19, 2017 | 01:47 PM
Big joe's Avatar
Thanks for your response I really appreciate it.
Couple other Questions if you happen to have any insight on & can help..
1.Are the Automatic Trans the same,..plugs & mounts,etc,,..
2.iyo Which would be easiest--> swap the entire Engine & tranny as one unit or just the motor.. & by which route dropping it out the bottom of car or pulling from the top..
The 95 has blown engine good tranny, the 91 donor , has both good engine & tranny, just totaled body..
Old May 29, 2017 | 03:48 PM
Big joe's Avatar
What's the protocol on the distributors, as the 1991 F22A1 has the coil inside the distributor & the 1995 F22B2 has the Coil mounted to intake..
Do I remove the coil from the 1991 F22A1 distributor & then use the 1995 F22B2 coil & mount it to the F22A1 intake & swap distributor caps, so the plug-in for the coil is used?
Or do I swap the whole distributer?
Or just use the distributor already in the F22A1 & don't worry about the plug-in/boot not being plugged in on the 95's wiring harness for the separate coil that was on the intake ?
Any info is appreciated, thanks..
Last edited by Big joe; May 30, 2017 at 12:16 PM. Reason: trying to be more clear in my Question
Old Jun 6, 2017 | 11:02 PM
Big joe's Avatar
For anyone considering this same swap, Be advised it is NOT a simple plug & play!
We are in the middle of swapping the motors & have run into several issues making things frustrating to say the least..
Now if anyone that has personally done this same swap by chance & would like to share 1st hand knowledge, my 16 year old & I would love for the help in order to get his 1st car on the road..
Old Jun 7, 2017 | 12:00 AM
You will use your existing distributor and coil. You will need to swap pins A6 and A11 at the ecu connector after popping open the back of the ecu connector.
.:FFS TechNet : OBD1 ECU Pin out Schematics :.
You can use your existing tranny and tcu. You will need the accord ecu. You will need the accord driver side engine mount.
Old Jun 19, 2017 | 08:52 AM
Big joe's Avatar
This link is dead Now (not sure) If this is the same pin out schematics here ---> .:FFS TechNet : OBD1 ECU Pin out Schematics :.
So we have removed the pin terminals & pin A6 & A11 are not the same size, in order to swap them we would have to change terminals/ or splice wires or are we doing something wrong.. thanks
Old Jun 21, 2017 | 04:11 PM
you can just cut the wires there and put a couple connectors on em and swap em
they should be the same size tho
AdamN
May 5, 2011 04:02 PM
k20efcrx
Aug 16, 2009 04:49 PM
DEJ203
Jul 17, 2008 07:46 PM
ERC RACING
Northern California (Sales)
May 19, 2006 08:14 PM
