sunroof tilt problem
Old May 17, 2017 | 05:18 PM
eddie7978's Avatar
Default sunroof tilt problem
1992 civic si
the open and close buttons work (top and bottom buttons)
the middle button (tilt) does not work when sunroof is closed
however when i open it a little with the top button and then press the middle tilt button, it just opens it to about halfway
i know the middle tilt button is suppose to tilt it up when the sunroof is closed however it does not
how can i diagnose this issue?
Old May 18, 2017 | 02:48 PM
eddie7978's Avatar
Default Re: sunroof tilt problem
ok well its not the switch i ruled that out with a power probe..
wheres tbe relays for this?
Old May 18, 2017 | 02:51 PM
eddie7978's Avatar
i find it strange that when i open the sunroof a little with the open button and then press the tilt button it opens it more to about halfway lol that tilt button should not do that it only is suposto work when it's closed to tilt it up and that's it
Old May 18, 2017 | 04:11 PM
Nedrobmas's Avatar
5 Year Member
Have you tried cleaning the openings and lubricate where it slides with a specific lubricant? How does it work with the car off, car idling, and driving?
Old May 18, 2017 | 04:13 PM
eddie7978's Avatar
everything seems to be fine.. it operates perfect besides the middle tilt button.. it doesn't make a noise at all
Old May 19, 2017 | 07:36 AM
Nedrobmas's Avatar
5 Year Member
I would first check the fuses under the dash, No.1(30A) and No.14(20A)
Check the under dash fuse box, the area right above your left foot when seated or in the 7 or 8 o clock position from where the switch is(assuming its to the left of the steering wheel facing foward). I thinks there two of them, the OPEN relay wire colors: Grn/Blk, Grn/Red, Wht, Grn/Yel, and Blk & CLOSED relay: Grn/Blk, Yel/Red, Wht, Grn/Yel, and Blk. Inspect them for any type of damage then test for continuity.
Old May 23, 2017 | 05:26 PM
eddie7978's Avatar
well i swapped the relays out with working ones and still nothing the same ****
swPped switches out and still nothing..
Old May 23, 2017 | 05:51 PM
Nedrobmas's Avatar
5 Year Member
Not sure why you swapped out the relays, but the motor might be nearing the end of its life. You could try looking at it when it's sliding back & forth, is it being stopped by something, off track, dirt, sticks, not aligned, rails rusted, cable needs replacement, etc. I would never replace anything until I find the source of the problem because I suck at gambling.
Old May 23, 2017 | 05:53 PM
eddie7978's Avatar
i tried different relays and different switch.. the motor seems fine it opens and closes fine.. tilt does nothing no noise nothing.. if i open the sunroof a little then press tilt it opens it to about halfway for some reason and that's it
Old May 29, 2017 | 05:03 PM
eddie7978's Avatar
wheres ron j when you need him
Old May 29, 2017 | 05:52 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
The two relays for the sunroof are under the dash, near the top on the drivers side.
I honestly do not believe you can access them without pulling the dash out.
They sit up beside the left drivers air vent on a metal bracket.
nvm, sounds like you found them.
You should see about getting an ETM for your vehicle.
My books are curently packed away so I can't post the relevant pages for you until after August when I move.
Old May 29, 2017 | 06:08 PM
Borexxx's Avatar
I'm experiencing almost the same problem, my middle button which is the "tilt" button doesn't work.
How to tilt my sunroof when it's close - Long press the close button
How to close the tilt back to flat - Press the slide in button several times until you see the sunroof kiss it's stopper. you need to get the perfect timing though, pressing the slide in too much will open it again.
I'll have this fixed soon.
Angela Barnett
Nov 21, 2017 07:47 PM
joysarkar
Aug 20, 2010 07:15 PM
Ri'can Luder
Aug 3, 2006 12:08 PM
asianalbutt
Sep 15, 2005 06:24 PM
