Honda CR-V & Element 2WD & 4WD Element & CR-V
Sticking Brake Caliper
Old May 12, 2017 | 02:06 PM
93962's Avatar
Default Sticking Brake Caliper
My Hunder CRV 1997 Sticking Brake Caliper at times the pedal will be soft and goes flat when moving after pumping the brake it holds but while on motion, the brake pedal will coming up and become very strong .
Old May 12, 2017 | 11:12 PM
holmesnmanny's Avatar
Default Re: Sticking Brake Caliper
sounds like a vacuum issue, possibly a bad check valve, or cracked hose
Old May 13, 2017 | 05:41 PM
eksine's Avatar
Never ran into that problem but if it's not holding pressure I would have guessed that seals in the master cylinder went bad or the brake booster went bad. A Cracked hose you would be losing brake fluid. I didn't know that it had a check valve but that sounds about right
hteg12
Jul 18, 2013 05:13 PM
slowesteg
Suspension & Brakes
Sep 4, 2012 08:24 PM
Whatislove
Honda Civic (2001 - 2005)
Jan 24, 2012 03:40 PM
UltimX
21
Feb 8, 2006 08:29 PM
MiX
Jun 20, 2004 10:47 PM
