92 delsol b16a wont start, no crank, no lights on dash
Old May 11, 2017 | 07:34 PM
Jv Ang's Avatar
Default 92 delsol b16a wont start, no crank, no lights on dash
Hi im new to this forum not sure if someone had the same problem im having now. So after work drove home with my delsol started fine and drove fine. After 15mns i was gonna go and get gas but car wont start. Like no power at all, in On Position no dashlights on,tried starting no crank at all. Friend had to boost me it started right away drove and got gas. After it woukdnt start again no power at all. SO NEED HELP WHAT COUKD BE THE PROBLEM.
Old May 11, 2017 | 08:06 PM
Chance EG's Avatar
Default Re: 92 delsol b16a wont start, no crank, no lights on dash
Battery/Alternator.... Low chance the computer could have fried out I guess.
Old May 12, 2017 | 04:03 AM
mk378's Avatar
Bad connection at the battery, or bad battery. I had a battery do exactly that once. Something broke inside. It went from normal starting to zero volts in one start. A voltmeter would be very useful to troubleshoot this.
Old May 12, 2017 | 02:32 PM
Jv Ang's Avatar
ok thanks guys i might check for my grounds aswell. Just remembered on my drive home hit couple of potholes.. So was thinking somethng went loose.
Old May 13, 2017 | 03:56 PM
White_EG1's Avatar
Are you in the states?
Old May 13, 2017 | 04:06 PM
Jv Ang's Avatar
Canada. Everythng is fix just loose ground
Kruegs35
Sep 14, 2016 05:28 AM
micah_m
Aug 19, 2016 10:50 AM
mistablaz3
May 9, 2011 01:01 PM
jonnybadboi9
Jul 18, 2007 04:34 PM
SOKDO
Jun 2, 2005 10:33 AM
