Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2005 Civic Ex Special, P2646, 4k Rev limiter
Old May 10, 2017 | 10:34 AM
legendor's Avatar
Default 2005 Civic Ex Special, P2646, 4k Rev limiter
Hello,
I have looked around for a while online trying to find some more information on this problem, and have seen this site pop up a bunch. Here is the complete list of events...
  • March 2017: Broken steering column rack and pinion bolt, along with P2647(https://www.autocodes.com/p2647_honda.html) CEL code
    • Repaired, and CEL dissapeared
  • April 2017: Car overheated, and I kept driving for a while, refilling coolant, etc.
  • May 2017: Finally took car in, and diagnosed a broken head gasket
  • May 2017: P2646 code remained, so I took back to mechanic and he said that he overfilled the oil. He drained it and refilled, cleared the codes, but P2646 CEL code comes back at 4k rpm.
This brings me to my current situation.
  • P2646 shows in BOTH pending and stored codes
  • Once hitting 4k rpm, Car stutters and shakes and will not allow any acceleration or going past 4k rpm
I am hesitant on taking it back to the mechanic I had previous work done, just because it is likely a VTEC problem that I feel a Honda dealer would be better equipped to fix...but I have heard stories of the whole VTEC system being replaced when all it needed was the Oil Pressure Switch.
P2647 = GENERIC( 'A' Rocker Arm Actuator System Stuck on Bank 1), HONDA(Rocker Arm Oil Pressure Switch Circuit High Voltage)
P2646 = GENERIC ( 'A' Rocker Arm Actuator System Performance / Stuck Off Bank 1), HONDA(Rocker Arm Oil Pressure Switch Circuit Low Voltage)
Any thoughts/suggestions? I am new to cars, and really didn't know anything at all about them until March.
Thanks
Old May 10, 2017 | 11:26 PM
toyomatt84's Avatar
Sanji
Default Re: 2005 Civic Ex Special, P2646, 4k Rev limiter
The 4k Rev. limit is due to your ECU being in LIMP Mode. With an active CEL, you're not going to be able to get out of LIMP mode. You'll need to remedy the problem first.
jwagner
Engine Management and Tuning
Apr 8, 2012 07:38 PM
crxowner
Oct 12, 2011 02:54 PM
nicefighter80
Jan 15, 2011 08:53 AM
Zerotls
Nov 17, 2008 09:40 PM
soeurm
Mar 19, 2007 05:41 AM
