B16A2 lower motor mount
Old May 10, 2017 | 09:44 AM
Em1 andy's Avatar
Default B16A2 lower motor mount
I have a 2000 civic SI and I need the lower motor mount the one on the transmission side I know someone parting out a GSR and wanted to know if I can use the mount off of that car? Also are these mounts really necessary cause I just bought the car and it didn't come with ether of the lower mounts but I got the one for the AC compressor side
Old May 10, 2017 | 11:39 AM
1999 Civic Si's Avatar
Default Re: B16A2 lower motor mount
Part #50843-S04-N10 is the bracket that bolts to the transmission. Fits the following based off of honda/acuras interchange 96-01 integras (manual transmission), 99-00 Civic Si, 96-97 Del Sol (not sure on sub model, but I would assume its the one with the b16a3). Some people say they are needed, others say they aren't. If you have softer/stock mounts I would keep them. I have 75a hasport mounts and I still have both of mine (with energy suspension inserts), some people with really stiff mounts remove them and call it a day.
The actual rubber mount itself should be the same for the passengers side for the cars I listed above, I would have to check on the drivers side.
Old May 10, 2017 | 04:25 PM
Em1 andy's Avatar
oh ok I also have hasport mounts so do u think I should buy the mount or just leave it without that side
atmosphere
15
Oct 7, 2025 03:53 PM
[626]95-GSR
Nov 20, 2005 09:15 AM
M.K.C.
Dec 9, 2003 03:40 PM
drewlee
Feb 24, 2003 09:03 AM
HKxBlur
Dec 27, 2001 10:00 AM
