b16a2 with automatic y8 harness ..puzzled
Hey guys , It's a 99 Acura el obd2b (manual) Car with a b16a2 from an obd2a delsol..here's the thing though , I had to use an automatic d16y8 obd2b engine harness changed the Iacv to 2 wire , and rewired the dizzy to run the big plug from the obd2a. Got the motor in and running good , but I had it out for a drive to notice the speedo not working .tach, dash lights gauges were all working and would light up with key on ignition , but no speedo so no vtec. I get out of the car and check the Vss (speedo sensor) Had a laugh cause I forgot to plug it in, did so and proceeded from there ,&$;$-/ SILL, no speedo! And no reverse lights? The gauges were faint on the cluster at night time also too,I also have no reverse lights and a bunch of left over plugs from the auto sensors that have a some same plugs and some black with blue insert plugs probably for evap? I deleted that out so it should have a CEL, but no CELs .p2T 99-00 b16a2 Ecu in the car , I'm wondering if I fuct something up or mixed matched plugs... Sigh..any help is very appricated as I searched lots on the auto harness couldn't find much , and I'm a noob it was my first swap.
rsdriver17
Jun 12, 2018 06:18 AM
No VDUBS here in206
Jan 15, 2009 08:03 AM
donvito#1
Mar 12, 2008 09:45 PM
dynamo
10
Jul 11, 2005 04:11 PM
