91 hatch recycle air lever opening at high rpm
Old May 8, 2017 | 08:41 AM
Sleepiness760's Avatar
Default 91 hatch recycle air lever opening at high rpm
I have a 91 hatch with a 95 gsr swap. Everytime I hit around 4k rpm on the highway, my recycle interior air level flips open. Assuming it has something to do with a vacuum leak, I checked all of the engine bay vacuum lines with a propane torch. I could not find the leak at idle. Does anybody know what else could be causing this issue? Thank you in advance.
Old May 8, 2017 | 07:29 PM
Default Re: 91 hatch recycle air lever opening at high rpm
Could this issue be caused by a/c system being removed? Maybe its just the speed on the highway causing air to force it open?
Old May 8, 2017 | 09:45 PM
boibuddha's Avatar
The outside air pressure is opening up your recirculating vent. Mine does the same thing at any speed above 50 mph.
I can get it to stay closed sometimes if I have the fan blowing on maximum and I hold the handle for a few seconds.
Not sure if the issue is on the lever side of the cable or the vent, but the opening and closing after 25+ years of use probably wore down whatever the basic keeper mechanism was.
Old May 13, 2017 | 01:39 PM
I guess I will just plug up the intake. Everytime it flies open my cab temp raises about 15 degrees. Its already hot enough down here.
Gabriel Ale
Honda CR-V & Element
Dec 23, 2018 06:29 PM
scrolanky
Nov 5, 2008 07:21 PM
lsturboguy
Sep 4, 2006 01:37 PM
jolt-tsp
Jun 27, 2006 09:01 AM
matix
Sep 20, 2003 09:36 AM
