2000 CR-V overheating
Hey guys, new to the forum. Found that I had a leak in the upper radiator hose so I replaced it, but where it connects seems to have a leak. Trying to find out what that part is called to get a new gasket for it if there is one or what the best thing to do to reseal it with.
Also the lower radiator hose that goes to the thermostat housing will not come off. Any tricks to get this off?
What on earth happened to your rear cam plug?!?! It looks like it's been mummified with RTV! Those are a very easy replacement item if they start leaking, you know. I just did mine about 3000 miles ago. Here's the part I bought:
Honda Cylinder Head Rear Cam Plug With Seal 12513 P72 003 | eBay
Simple 6-dollar fix, which might even be cheaper than a tube of gasket maker!
CptHMCrunch
Sep 13, 2013 06:29 PM
