Leak around radiator hose.
I have a water leak where the upper radiator hose meets the head. I was wondering if its a liquid gasket or a regular one that goes inbetween the hose and the head.
Thanks...
Thanks...
Re: Leak around radiator hose. (steve_s)
there is no gasket between the hose/water neck.....you just have to use a hose clamp and tighten it down on the neck, then the leak should go away unless the hose is cracked.....good luck
Re: Leak around radiator hose. (SpoonFedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonFedHatch »</TD></TR><TR><TD CLASS="quote">there is no gasket between the hose/water neck.....you just have to use a hose clamp and tighten it down on the neck, then the leak should go away unless the hose is cracked.....good luck </TD></TR></TABLE>
what he said
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steve_s »</TD></TR><TR><TD CLASS="quote">I have a water leak where the upper radiator hose meets the head. I was wondering if its a liquid gasket or a regular one that goes inbetween the hose and the head.
Thanks...</TD></TR></TABLE>
hmm yeah its only liquid gasket. good luck with that..
CptHMCrunch
09-13-2013 06:29 PM
B16Civic93
03-03-2005 05:15 PM
