Confused Civic
Old May 7, 2017 | 01:04 PM
DemonicCivic's Avatar
Default Confused Civic
Hello all fellow HTC ppl forgive me if this is in the wrong spot just wasn't sure what it fit the best so with that said il start from the beginning I bought a 1998 Honda Civic ex coupe on the cheap a month or so ago and after having it a little bit and having a closer look the previous owner has put a d16z6 bottom end with a d16y8 head in the car and from what I can see it still has the factory P2P ecu in it and the issues are IV got a cel light on with a knock sensor code as well as a srs light on and my car runs like **** and I'm not sure exactly what to do I was thinking about changing the ecu to a chipped p28 with a jumper harness and go from there any advice would be greatly appreciated
Old May 7, 2017 | 08:51 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Confused Civic
The SRS code is totally separate... no ECU choice will turn that light out. You will have to solve that by checking the SRS trouble codes and trouble-shoot that system from there.
Using a P28 and a jumper harness will turn the KNOCK sensor code out, but that will not necessarily cure the "runs like ****" problem as you put it. Has it run this way ever since you purchased it or is this a recent development ???
EJ1Shifty
10
Nov 20, 2018 08:59 AM
APAem1
Jun 3, 2010 09:42 AM
JunkyardDog
Dec 19, 2005 05:19 PM
hatchboy93
14
Apr 23, 2003 10:02 PM
Shft@9GSR
Feb 10, 2002 12:04 AM
