Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
SRS light
Old May 7, 2017 | 11:01 AM
crosk1189's Avatar
Default SRS light
I have a 2003 Honda Civic inspire S (RHD). I was involved a collision which damager an airbag sensor, I have replaced it and have used a code reader to check if the fault is still there and it says there's no fault and no code to erase. However the SRS light is still on, I have fixed the fault, check the fuse, used a code reader which is now saying 'no fault' and still the light is staying on. Can anyone make any suggestions what do I do?
I have even tried to find the port for the paperclip trick as suggested in this video
But as mine is UK so right hand drive I can't find it anywhere.
Old May 7, 2017 | 09:44 PM
prodjay10's Avatar
Default Re: SRS light
Which scan tool did you use? Did it have access to the airbag system?
Old May 8, 2017 | 01:55 AM
crosk1189's Avatar
It is the Foxwell auto master, it has access to airbag system, I scanned the airbag system and it says no faults yet the light is still on.
Old May 9, 2017 | 12:07 AM
prodjay10's Avatar
I believe you have to have the SRS unit reprogrammed to get it to work and the light to go away.
deanwashere
Jul 25, 2018 04:28 AM
RATEDR
Jul 13, 2009 11:51 AM
ashmelev
Apr 24, 2007 03:06 PM
97RSTEG
Jun 24, 2006 12:10 PM
slowcivic888
Dec 15, 2004 06:32 AM
