Need Help Don't know what's wrong
Old May 7, 2017 | 09:09 AM
B20bB16a's Avatar
Default Need Help Don't know what's wrong
I've got a B20b block with a b16a head and yesterday my car kept killing on me and after a while the battery was completely dead, we had adjusted the alternator a day or two before and that belt was super loose the bolt slid it forward. Fixed that but when I was driving it home and I went to shift it would die. Had to keep pop starting it, got it home and coolant was bubbling in the resivour and it was dripping a bit out for about a minute then it stopped. Felt all the hoses and they were super hot but my car never said it was over heating. It was hot on all hoses, any ideas? Hoping it's not a headgasket.
also we were street racing yesterday and the guy behind me said I was misting out my exhaust wasn't oil either water or coolant but I had just got a car wash like 15-20 min before that so it could've been water.
Old May 7, 2017 | 09:29 AM
B20bB16a's Avatar
Default Re: Need Help Don't know what's wrong
Update car isn't starting trying to crank over but cant
Old May 7, 2017 | 09:38 AM
Chance EG's Avatar
Do a compression test and let us know how that turns out... lol
Old May 7, 2017 | 09:43 AM
B20bB16a's Avatar
My top hose burnt my hand when I tried squeezing it but the bottom is cooled down has been sitting for about an hour. I'll compression test it
Old May 7, 2017 | 10:28 AM
mk378's Avatar
Sounds like more than one problem going on.
Hook up a battery charger so you have plenty of juice for the compression test. If you ever get the engine started again, check the charging system by measuring battery voltage with the engine running.
A car wash will not make any water come out the tailpipe. Unless you're washing your car by dunking it in a lake.
Old May 7, 2017 | 10:39 AM
B20bB16a's Avatar
I removed the top house because it looks like the coolant is trapped and can't get through. Possible thermostat? But would that keep it from starting?
Old May 7, 2017 | 10:56 AM
B20bB16a's Avatar
Car started was really low rpm for the first 30 seconds but then I fixed it self. Making a ticking and a bit of a knocking noise. Hoping it's not what I think it is.
Old May 7, 2017 | 11:01 AM
B20bB16a's Avatar
Could it be a possible bad injector?
Old May 7, 2017 | 12:43 PM
Chance EG's Avatar
No... You effed up your engine. It's been obvious since the start. That's why I want you to compression test it, so you can see the failure for yourself.
Old May 9, 2017 | 07:23 AM
andrewsantana61's Avatar
Check the spark plugs any kind of smell of gas? Are they wet?
Old May 15, 2017 | 07:29 AM
B20bB16a's Avatar
Compression tested 150 for all cylinders
Old May 15, 2017 | 07:33 AM
B20bB16a's Avatar
nope they're fine
b18egtheehatch
Feb 17, 2015 08:12 AM
Mr.Volks
Jan 11, 2010 07:52 AM
clevis88
Honda Civic (2001 - 2005)
11
Jul 1, 2006 09:24 AM
94lsboost
Nov 20, 2003 01:11 PM
JspechHATCH
Apr 28, 2003 03:09 PM
