Dreaded idle surge...
Old May 6, 2017 | 11:30 PM
bestofthe80s's Avatar
Default Dreaded idle surge...
Hey all, I have a 2001 accord sedan with the 4cyl sulev and automatic transmission. Car has sat for awhile and now has an idle surge issue.
- Car will fire up, idle fine for a minute or two, then begin to idle surge... rising and falling.
- Only behaves this way when the transmission is in park or neutral, when in gear it idles and revs normally.
- I have removed and cleaned the throttle body with intake cleaner.
- No visible vacuum leaks or missing hoses/wires
Wondering what the steps might be to diagnose the issue. I have been reading and watching videos... multiple causes for this common issue seem to be discussed, most of the time leading on a goose chase with not fix found. I am wondering what my order should be to isolate the issue?
My suspicion is the cold air idle valve... should i attack this first?
Whats the next cheapest/easiest things to try to fix this issue? Have you had this problem? If so, what fixed it for you?
Old May 7, 2017 | 05:34 AM
poorman212's Avatar
Default Re: Dreaded idle surge...
Check and bleed the coolant.
Old May 7, 2017 | 05:21 PM
Problem solved!
I removed the intake, removed the throttle body, removed the IAC Valve on the back of the intake. Valve was gummed up, I had to purchase a 5 point star bit to remove sensor. This valve is unique to the ULEV and SULEV models I think? I cleaned the valve with intake cleaner and moved it, wiggled it free, it was totally stuck and after cleaning it would click and rotate back and forth, opening and closing the valve easily. Re-installed and idle surge gone! Woot!
23nesnes
Sep 22, 2009 10:21 AM
sun_zinc
Jul 13, 2008 01:19 PM
SilverSellout
12
Feb 27, 2004 12:48 PM
RedStarGsr
Jan 7, 2004 12:01 PM
mrpickyman
Nov 2, 2002 05:22 PM
