97 Vtec Del Sol PS Leak
So i have refilled my power steering about 6 times so far, because it was leaking. I know i waited and im stupid. I found the rack and pinion on this site 1993-1997 Honda Del Sol Rack And Pinion (V-Tech DOHC) which i am going to order. I wanted to know if my delay in repair has caused issues with PS pump or anything else. So that i can simply get everything fixed at the same time. I take full responsibility for being a lazy *** and if i need to spend more now because of that i accept that.
If you didn't let the pump run dry or use an incompatible fluid, no problem.
A lot of generic fluid is "not for Honda" somewhere in the fine print on the bottle because it will ruin the seals.
