97 Vtec Del Sol PS Leak
Old 05-05-2017, 10:05 PM
xboxhaxorz's Avatar
Default 97 Vtec Del Sol PS Leak
So i have refilled my power steering about 6 times so far, because it was leaking. I know i waited and im stupid. I found the rack and pinion on this site 1993-1997 Honda Del Sol Rack And Pinion (V-Tech DOHC) which i am going to order. I wanted to know if my delay in repair has caused issues with PS pump or anything else. So that i can simply get everything fixed at the same time. I take full responsibility for being a lazy *** and if i need to spend more now because of that i accept that.
Old 05-06-2017, 05:10 AM
mk378's Avatar
Default Re: 97 Vtec Del Sol PS Leak
If you didn't let the pump run dry or use an incompatible fluid, no problem.
A lot of generic fluid is "not for Honda" somewhere in the fine print on the bottle because it will ruin the seals.
Old 05-06-2017, 12:17 PM
xboxhaxorz's Avatar
I did use non honda fluid from walmart, the big bottle too
ray559527
Engine Management and Tuning
06-05-2011 05:25 PM
CopperSol
01-19-2006 12:51 PM
earthworm
06-02-2005 08:37 PM
Chingowtumadre
09-15-2003 12:28 PM
lgndry
07-07-2003 12:52 AM
Quick Reply: 97 Vtec Del Sol PS Leak
