B20b won't start
Old May 5, 2017 | 05:26 PM
Tmp157's Avatar
Icon4 B20b won't start
Need help! I've spent hours searching for threads that were identical to my problem but had no luck. I swapped a jdm b20b into my 98 ek hatch. Everything is wired correctly (triple checked) but the car won't start., and when it does it goes straight to about 4000-5000 rpm and and then shuts off. CKF bypass done correctly as well as the 3 wire to 2 wire iacv. The motor cranks fine but when it does start up, it's as if the throttle is wide open. I swapped the plugs for the tps and map sensor just in case I accidentally mixed them up, but no luck.
My set up is a 99 jdm b20b with a skunk 2 intake manifold, skunk 2 70mm throttle body, aem fuel rail with fuel pressure regulator, obd2 LS injectors, obd2 LS distributor and a obd2 P75 ecu.
Any help would be appreciated.
Old May 5, 2017 | 08:00 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B20b won't start
Put a stock throttle body on the intake with the proper T/B gasket and try again. Also, check your PCV valve and make sure you don't have an internal vacuum leak.
Old May 5, 2017 | 08:09 PM
Tmp157's Avatar
PCV valve is brand new. The motor is fresh from hmotors with a full compression/leak down work up. Ill try swapping out the throttle body to the stock one tomorrow as its now raining.
Old May 12, 2017 | 08:18 PM
Tmp157's Avatar
Hey thanks for the help. It turned out being an air leak from the intake manifold gasket. It was installed with the proper torque specs, but perhaps it didnt seat right. Got it started up and running solid.
dnxracer
Sep 15, 2017 01:16 AM
Tmp157
May 5, 2017 05:19 PM
Alexpbnj
Dec 6, 2010 06:35 PM
Alexpbnj
Dec 6, 2010 02:52 PM
jimmyrab
May 13, 2008 04:53 PM
