Sorry if this has been posted before but I have a really specific picture of a leak I get on the passenger side carpet when there is heavy rain. Any one see a leak of this type? Just looking for a short-cut to narrow my investigations before I try to fix it.
I do have a moon roof. That was one of my two thoughts. The other was the rubber seal on the roof where it meets the window. The drain seems to be the most common thing. Thanks
Had the same problem on a 94 lx accord. Didn't have moonroof though, but the issue was that the door had some drainholes/pipes that were backed up, if you have an air compressor, you can blow some air into the pipes and the problem should fix itself after that.
