long story short. It was mines then my pops he got sick with cancer and sold it and passes away and I had to get the car back in his memory and now trying to finish it up the right way and run 10s as he wanted and then maybe even a 9 sec pass. its always been a street car. when we had it it was built in memory of my aunt she passed away of cancer and that's why there was pink involved. Ill be leaving some pink on the car and majority will be blue for the colon cancer support and his memory. Tranny: S1-1043830 B18C1 81.5 bore Eagle Block Guard Wiseco Piston (9-1) Eagle Rods B16 VTEC HeadSupertech Double SpringsSuper tech retainersOEM Valves ITR Intake Cam GSR Exhaust Cam GSR Hydro with lsdCompetition Clutch Stage 5 Rigid - Strip Series 0420 Clutch Kit 62/62 turbo Tial BovH
ondata S300 (Boost by Gear) v3 Intake (JG Edelbrock) Fuel Rail (Pro Series Eagle) Injectors 2200cc Bosch Sumped fuel tank Bosch 44 fuel pump Aeromotive Fuel Pressure Regulator Black Works Racing Radiator/Flex-A-Lite Fan
Red Top Optima Battery Grant Wood Steering Wheel
KYB Shocks and Megan Coil Overs
3inch exhaust front to back Vibrant muffler
Chromoly roll cage
^ list before the upgrades how car has been for a while
when we first got it and swapped a b series in it
these are all from before when we had it at first and manifold was done and then coated two different times and colors
these are pics from when I have gotten it back oct of 16 and the stuff I have changed, gotten and the progress on the car. got the vc re coated, new bumper lights and turn signals, added new 2200 cc injectors, new fuel filters , a lot of upgrades will be happening like new cams (skunk 2 tuner stage 2) hydro clutch conversion, new turbo kit, hood lashes, booster tuck, solid mounts inserts, new innovate traction bar and shift linkages, 44mm tial wg, k tuned b series shifter, skunk 2 black rad hoses, hondata got upgraded to v3, new coolant reservoir and radiator, picked up DA brakes to convert the rear, titanium springs and retainers, type r oil pump, gates race timing belt, Weldon fuel pump, momo steering wheel with short hub and detachable, hard race rear control arms, new powder coating, hondata cop kit etc I think there is a little more but that's what I can remember right now.
im sure im missing some stuff but yeah here is the progress so far, cant wait to get it done and back out.
thanks yall, head went off to machine shop today and a few parts getting ordered for the motor, new oil pan gasket, bearings, vtec delete kit and valve cover stud kit
head should be back from cleaning/ pressure test and 3 angle valve job next weekend. motor coming out this coming up week, got some more parts on the way like oil pan gasket, valve cover stud kit, vtec delete kit and rod bearings.
