93 Del Sol SI parking lights stuck on need help
Old May 4, 2017 | 06:20 PM
Taylor Lanier's Avatar
Default 93 Del Sol SI parking lights stuck on need help
Sorry if this is in the wrong spot, I just registered because I need help. I'm generally new to cars, and just started educating myself on my (new to me) Honda del sol. Anyways, my back lights are on and won't turn off. I'm assuming its my switch on my steering column but I don't know for sure. I've pulled all the interior fuses (one by one then put them back in) and they didn't turn off. I'm in desperate need of a temporary fix. Something I can do to turn them off while i'm at work or sleeping so it doesnt kill my battery, any ideas?
Old May 4, 2017 | 06:41 PM
Default Re: 93 Del Sol SI parking lights stuck on need help
Quick update, a guy approached me at work like 25 minutes after uploading the post. It's actually a small piece under my brake pedal that is missing, the piece pushes the pin, turning my lights off. I have no idea what this piece is called or where to get one. Any ideas?
Old May 5, 2017 | 03:07 AM
NVturbo's Avatar
O.G. triple O.G.
it's not your parking lights, it's the BRAKE lights that are staying on.
brake switch
36750-SR3-003
local parts store, ebay, Craigslist, Honda dealership, salvage yard.....
Old May 5, 2017 | 04:21 AM
mk378's Avatar
To keep the battery from running down, remove the stop / horn fuse. That fuse is in the fuse box next to the battery, not the one under the dash. Do not drive with no brake lights though.
Old May 5, 2017 | 11:44 AM
Icon7 Re: 93 Del Sol SI parking lights stuck on need help
brake switch
36750-SR3-003
Thank you sir, I only thought it was the parking lights because when I pressed the brakes, my outside brake lights turned on too (only the inside lights were stuck on, not the corner ones).
And thanks for the temporary fix, I stuck a screw where I was missing the brake switch until I can go to the store today.
Sorry for the noob questions guys, I'm still learning!
Neth
Jul 27, 2015 07:53 AM
Mark-e
10
Mar 21, 2013 06:03 AM
yESSSmAn
Apr 15, 2009 07:42 PM
srg
Jul 20, 2006 08:32 AM
