Suspension & Brakes Theory, alignment, spring rates....
Sway Bar Help.
Old May 4, 2017 | 04:13 PM
a_benito86's Avatar
Default Sway Bar Help.
I have 98 Civic Hatch. Bought this sway bar used.
Seller claimed it was from a 2000 Si.
The end links are from Rock Auto for a 2000 Si that i bought, but they dont seem to be lining up.
Do i have the wrong sway bar?
Old May 5, 2017 | 03:33 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Sway Bar Help.
does it look the same on the passenger side?
Old May 6, 2017 | 12:34 AM
kristo's Avatar
Loved
Icon3 Re: Sway Bar Help.
Looks legit however the bar looks as if it sits a but too far to the right (exhaust side), you might want to align it.
Did you use some sort of backing plates on the other side of the subframe where the support brackets are mounted to -SI has those standard?
This is my EK4 15mm setup -same as SI for that the SI is 13mm- with ASR backing plates.
Old May 8, 2017 | 10:59 PM
a_benito86's Avatar
no i just used bolts and nuts from the hardware store. Is a backing plate needed?
Old May 8, 2017 | 11:46 PM
kristo's Avatar
Loved
Icon4 Re: Sway Bar Help.
Nah, me and others just like spending money at and rocking small exotic parts
Try Subframe tear out
theguy22
Suspension & Brakes
13
Aug 19, 2018 08:02 PM
RetroGamer
33
Aug 19, 2011 03:50 PM
gsrhb7
Northwest (Sales)
Oct 27, 2006 07:56 PM
NTGR8D
Mar 13, 2003 11:13 PM
EleanoR
27
Jan 21, 2003 07:45 PM
