Fuel tank same between EG hatch and sedan?
Old May 3, 2017 | 11:06 PM
Custard's Avatar
Default Fuel tank same between EG hatch and sedan?
Just need to know whether the fuel tank from an EG sedan is the same as in a hatch. Anybody know?
Old May 4, 2017 | 03:27 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Fuel tank same between EG hatch and sedan?
SAME
Part #17500-SR3-316
Old May 4, 2017 | 03:43 AM
Custard's Avatar
Originally Posted by NVturbo
SAME
Part #17500-SR3-316
Aw yes, thanks!!
Old May 5, 2017 | 08:29 AM
94eg!'s Avatar
#1 Super Guy
Loved
Keep in mind the CX & VX hatchbacks have a smaller tank. 17500-SR0-325. You could potentially run into small issues if you have one of those trim levels.
Old May 5, 2017 | 08:35 AM
NVturbo's Avatar
O.G. triple O.G.
The mounting should be the same..right?
Old May 5, 2017 | 09:28 AM
94eg!'s Avatar
#1 Super Guy
Loved
Yeah. I would just verify any parts you are going to transfer from one tank to the other are interchangeable. Things like fuel level sending unit and fuel pump. You can do this by comparing parts numbers on any of the parts websites.
If you are getting a complete tank assembly with everything on it, then it should be a pretty straightforward swap (though I've never done one myself).
Old May 5, 2017 | 12:10 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
I was going to say, different trim hatchbacks didn't even have the same fuel tank.
Old May 8, 2017 | 08:49 AM
94eg!'s Avatar
#1 Super Guy
Loved
I just noticed the fuel sending unit (device that drives the fuel level gauge) is different for both tanks. If you switch to the bigger tank, be sure the one you buy includes the sending unit.
Also the sending unit for the smaller tank is no longer available anywhere. The one for the bigger tank is still available at the dealer.
Old May 9, 2017 | 04:18 PM
Outrun's Avatar
I wonder why the CX and VX only got 10 gallon tanks. Was it for weight savings? They'd go so much farther with an 11.9 gallon tank.
JDMDK
Jan 17, 2008 12:24 PM
StolenTeg
Aug 22, 2006 07:43 PM
Madrek
Nov 28, 2004 11:32 AM
