Honda CR-V & Element 2WD & 4WD Element & CR-V
02 CRV
Old May 1, 2017 | 02:19 AM
2ndchancefarm's Avatar
Default 02 CRV
Can anybody tell me where I can find an "engine oil flow" diagram? Having IVTEC problems, purchased the vehicle with a broken timing chain, replaced chain, guides, tensioner, solenoid valve and oil control valve. Getting code P1259, failing VTEC test immediately Previous shop had replaced timing components and dented the oil pan directly below sump pickup (already repaired). Getting 60 psi at idle, spikes to 80-85 at 3000 rpm (warm), I'm a 40+ year tech (Master Certified) and really HATE having an inanimate object kicking my butt! ANY ideas? Sometimes can't see the forest for the trees! I've got a feeling I've got a restriction somewhere in the system. Strange thing was, I ran Seafoam thru the oil and expected to see "dirty" oil when I drained it (and did), but when I removed the filter, the oil tat came out of it was clean!
2ndchancefarm
Apr 30, 2017 01:45 AM
pjr710
Feb 6, 2009 10:23 AM
RaVAGE00
Jul 1, 2003 04:36 PM
01PYTypeR#1140
May 19, 2003 08:12 AM
lucas569
Oct 7, 2001 10:46 PM
