Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission mount hole through case
Old Apr 30, 2017 | 10:54 AM
boomer411's Avatar
Default Transmission mount hole through case
Hello everyone
I bought a used gsr transmission and didn't notice that there is an actual hole through the transmission where the tranny mount goes. . . . can i still get away with this or should i try to find another transmission housing?
Old Apr 30, 2017 | 09:43 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Transmission mount hole through case
Your pictures show that the threads are destroyed almost all of the way down through the hole... a longer bolt was employed at some point to try and get to good clean threads at the bottom of the hole. TimeSert the hole and use some HondaBond on the bolt when you install it in the car. It may leak a bit from time to time, but this area is very high in the case and above the normal level of the fluid. This means that it will only potentially leak during actual operation... not while it sits.
Old Apr 30, 2017 | 10:14 PM
chuck chainz's Avatar
It seems like you can get it welded, since it's not in a place where forks or other parts enter the case.
Old May 2, 2017 | 11:10 AM
boomer411's Avatar
Where can i pickup time-serts?
Old May 2, 2017 | 11:51 AM
Ebay is a good place, Timeserts are pricey but 10x better than a helicoil.
Old May 3, 2017 | 11:09 PM
holmesnmanny's Avatar
jdm and usdm have different mounting holes, you may not need to do anything to it, double check it with your existing chassis
dth0ng69
13
Jul 10, 2011 12:16 PM
lilo_goki
Jan 5, 2011 08:36 PM
TEGRA98GSR
Apr 21, 2010 09:47 PM
ki11a8ee
13
Mar 14, 2004 03:09 PM
Pete_SI
Aug 9, 2003 03:55 PM
