B16 swapped out for B18c1
I'm not sure which B16 engine was taken out of the car, but it is a B18C1 how would I be able to tell if this swap was done correctly, other than I did drive it home almost 200 miles? Is there anything to lookout for, electrical or mechanical wise? Any specific parts I should look for? Is equipped with a Jackson supercharger. Car is un-tuned.
Did you ask the previous owner what was done to the car? Since it does have a supercharger, you could assume the injectors and fuel pump have been changed. At this stage you are probably better off taking it to a shop to have them look over the car for you and have it tuned also. Whatever you do don't drive the car hard until you get it tuned.
Jesterian
Sep 25, 2005 08:48 AM
