Honda CR-V & Element 2WD & 4WD Element & CR-V
DRL and high beams not working
Old Apr 24, 2017 | 02:18 PM
luvmycrv's Avatar
Default DRL and high beams not working
Hi There, I'm new to the group. I have a 2010 Honda CRV this is my 3rd CRV. Two weeks ago my AC stopped working and the tech at the shop wasn't sure of the problem. Now my DRL idiot light is lit on the dash. They do not work and my high beams are not working. My mechanic said I must have a bulb that is out. How can 1 bulb cause my DTR lights to not work or my high beams?? Could there be a correlation between my AC and lights not working?? I know it's a silly question.
Thanks, Stacy
Old Apr 24, 2017 | 07:50 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: DRL and high beams not working
Thanks, Stacy
Sounds like you need a new mechanic. Try Google or Yelp.
Also it is unlikely that the AC and lights are related....though in the automotive repair world anything is possible.
Old Apr 24, 2017 | 09:51 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If Honda stuck with their normal design from 95, the high beams and the DRL are on the same relative circuit. The DRL goes through a resistor box to the high beams.
Unless the AC and your DRL/High beam share a ground, I don't think they are related.
I think you may have aq grounding issue on the high beam side of the bulb.
Old Oct 30, 2017 | 01:38 PM
Paul Demsko's Avatar
I have a 2007 Honda Accord and I’m having a similar issue. My DRL light on the dashboard came on recently and now my hi beams don’t work. I checked the fuses and they look fine. Has anyone been able to resolve this issue? Thanks in advance for any help.
Old Oct 30, 2017 | 08:44 PM
stumped70's Avatar
It's possible both headlight bulbs are burned out on the bright side. Probably not likely but possible. Just something to keep in mind.
Caleb Wright
Lighting
Apr 24, 2017 04:39 PM
AznBlueBoy
Aug 9, 2010 10:29 PM
bidaly
Nov 15, 2007 04:27 PM
projectwidow
Dec 25, 2006 05:19 PM
tapuout
12
May 8, 2006 12:16 PM
