Itr brakes?
I'm looking to do a 5 lug brake conversion on my eg hatch. And I'm also installing a b16a2. Is it the 32mm swap that will work with the b16 trans or is the it 36mm? I looked a little online.
Either will work but you'll need to find JDM 36mm axles every time you want new ones and they are a bit hard to find. There are people that use prelude axles but the lenghts aren't the exact same and some say they pop out at times. Go with 32mm as any b series axle from the local parts store will do
JDM and USDM are the same when it comes to the trans. It's the hubs that are different sizes. Try to source USDM ITR 5 lug so you can use stock axles. If not, you can build them using late 90's CR-V axles.
Quickridez_3
Oct 27, 2024 10:18 AM
Garrett
Jun 7, 2004 06:49 AM
jp8900
Nov 12, 2003 10:27 AM
darkknightwong
Jul 18, 2002 02:22 PM
