Itr brakes?
Itr brakes?
I'm looking to do a 5 lug brake conversion on my eg hatch. And I'm also installing a b16a2. Is it the 32mm swap that will work with the b16 trans or is the it 36mm? I looked a little online.
Re: Itr brakes?
Either will work but you'll need to find JDM 36mm axles every time you want new ones and they are a bit hard to find. There are people that use prelude axles but the lenghts aren't the exact same and some say they pop out at times. Go with 32mm as any b series axle from the local parts store will do
Re: Itr brakes?
JDM and USDM are the same when it comes to the trans. It's the hubs that are different sizes. Try to source USDM ITR 5 lug so you can use stock axles. If not, you can build them using late 90's CR-V axles.
Re: Itr brakes?
Quickridez_3
04-21-2019 01:54 AM
Garrett
06-07-2004 06:49 AM
jp8900
11-12-2003 10:27 AM
darkknightwong
07-18-2002 02:22 PM
