Running rich or burning oil?
lsvtec ready to get tuned but car lets out blue smoke but ONLY in high rpms and when downshifting, NOT at idle. it doesnt burn more oil than your average honda engine but one thing is the car definately runs a little rich. I was told that when a car runs rich its likely it would burn more oil than normal. Any thoughts on this?
To test rings, get high up in RPM, in like second or third, and then brake down to like fifteen miles an hour. If your rings are worn it'll suck oil up, past your rings, into your combustion chamber. When you gas it again all the oil will burn in a nasty plume. When I first got my civic I could "roll coal" doing this. Other than that I would suspect stem seals. I've never heard of cars running rich burning oil. I mean does more fuel somehow make oil appear in your cylinder? I don't really see any logic in that claim.
If it's running super rich, the excess gasoline can wash the cylinders, making for a less effective seal and allowing oil to get past, or if like in my case before I fixed it, you're running so rich the excess gas gets into the crankcase and turns your oil watery.
EDIT: when I say I was at 10:1 AFR, that is misleading. It was actually a mystery AFR that was much lower than that, as 10:1 was the lowest the wideband read, and it was always at 10:1 unless I was coasting in gear.
Mine had an issue with the ECU, in that it ran everything great but fuel mixture was off the charts rich. I didn't even know until I purchased and installed a wideband, then saw that my chipped and dynotuned ecu was worthless because I was at 10:1 AFR constantly. (the lowest the wideband goes.) I can definitely say that my oil was affected by it, when I drained it out it had a viscosity closer to water than to 10w30.
If you're running anything other than basic bolt ons, you need to get it tuned by someone who knows what they are doing. My issue ended up being the ECU. Once I transferred the chip my tune was on to another socketed ECU, it ran perfectly with perfect AFRs.
EDIT: A basemap is NOT good enough. Your issue may in fact be resolved just by getting it dyno or street tuned by a professional.
the afr was getting fiddled with when that happened during some street tests. also this isnt a built block its a stock block essentially taken out of a totaled integra, has rod bolts and arp headstuds thats it. I know it shouldnt be beaten on which i dont personally its usually in my garage collecting dust but we decided to start to get going on this car so to get the afr close to okay it had to be run. Plus it wasnt redlined which is why i say its crazy because this car was pulling on a gsr full bolt ons shifting 1000rpms before redline. Like i said car runs mint for the basemap its on. Car should be getting tuned next week on monday by a reputable tuner here in ny.
skate1968
Jun 26, 2007 07:22 AM
Blazin Si
19
Jun 26, 2005 08:59 AM
