99 civic si throttle body
Old Apr 20, 2017 | 11:52 AM
Type 56's Avatar
Default 99 civic si throttle body
My old throttle body is all jacked up and i need a new one. But before i go off and buy a another one i just wanted to know what's the exact diameter of the throttle body or is it all 96-00 civic throttle diameter size is all the same?
Old Apr 20, 2017 | 08:54 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: 99 civic si throttle body
The Si has a 60mm T/B. The EX is slightly smaller at 58mm.
Old Apr 22, 2017 | 08:22 AM
Type 56's Avatar
I see. So the question is, should i stick with a 60mm throttle body or upgrade to something bigger like a 60-70mm+ throttle body instead? Will a bigger throttle body increased or decreased my vehicle performance?
Old Apr 23, 2017 | 03:52 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You wont' see any gains with a larger TB if you don't tune the car. And without tuning the car, you might actually hurt the response or performance of the car with the larger TB.
Also, using a larger TB most likely means port matching the intake manifold (IM). If you don't port match then it's no different than the stock TB but with a lip/ridge to cause more shock waves in the pre IM air tunnel, which could potentially choke the car out to some degree as well as negate any gains from a velocity stack.
Old Apr 27, 2017 | 04:23 PM
Type 56's Avatar
Aight. There's a guy trying to sell me his GSR TB along with the TB cable. Should i go for it? Will the TB and cable be compatible with what i'm looking for in terms of oem spec?
FATninja19
Jun 26, 2006 10:51 PM
tegSB85
Nov 17, 2005 05:50 AM
honda94civicturbo
Oct 14, 2004 12:58 PM
Fink2iCe
Aug 20, 2004 10:50 AM
