Torn pcb on cluster, fixable?
Old Apr 19, 2017 | 06:29 PM
Ray Satomi's Avatar
Default Torn pcb on cluster, fixable?
So I picked up a new cluster, and it didn't work when installed. When I checked the board on the back, the leads coming odd the plug for the left turn signal and switched 12v power were torn. Is this fixable? Was thinking I could just put sole solder over the gap, does anyone have experience doing this? Pic attached of that it looks like. From right to left, the connections that are torn are the left turn signal, 12v power, and an unused pin.
Old Apr 19, 2017 | 08:54 PM
bbarbulo's Avatar
Default Re: Torn pcb on cluster, fixable?
yes, can fix no problem
another option is to swap the entire film off another cluster with the same options (88-89 is different to 90-91, and tach is different than no tach; not sure about aut vs manual, but I suspect auto and manual will be the same traces). like if this was a rare cluster of some sort, like a EDM or JDM cluster, then sacrificing a $100 cluster to pull the traces off is worthwhile.
Old Apr 19, 2017 | 09:32 PM
Ray Satomi's Avatar
Is there any insulation on the top of the visable traces, so I can just plop a blob of solder on there and be good?
Old Apr 21, 2017 | 10:53 PM
bbarbulo's Avatar
it is insulated, see how the traces change color in the area where the plug goes, that's where the insulation ends.
but it should burn off with the soldering iron or clean up with some acetone on a qtip, then use flux paste to clean it up, then solder on a couple of traces of house thermostat wiring (the thin single strand stuff) to bridge the gap.
Old Apr 22, 2017 | 05:49 AM
RiPe14yoU's Avatar
+1
​​​​​​​This is definitely the way to do it just scrape down the traces some and solder a couple jumper wires on
Old Apr 23, 2017 | 06:52 PM
~sp33~'s Avatar
EFB055
I could never get solder the solder to stick.
Old Apr 23, 2017 | 06:56 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
If you picked up a new cluster, why not swap the old film to the new cluster?
Old Apr 23, 2017 | 08:03 PM
bbarbulo's Avatar
need to clean off the film first, get down to copper.
Old Apr 23, 2017 | 08:04 PM
bbarbulo's Avatar
presumably he bought a tach cluster to replace a non-tach cluster, the traces are not even remotely close for a swap
I really need to start using the "+ function
Old Apr 27, 2017 | 02:55 PM
~sp33~'s Avatar
EFB055
Yeah i used a spare cluster and tried right where the plug pin would contact the circuit. Maybe i didn't try hard enough and just assumed it wasn't possible. I'll give it another crack this weekend though.
Old Apr 27, 2017 | 03:05 PM
Ray Satomi's Avatar
Soldering it should melt the insulation away. I tried just bridging it with wire too, but after putting a nice glob of solder on the gap it works perfectly. I'll try to get some pictures to post next time I have the cluster out, changing it to LEDs when they arrive on Saturday. (Hype!)
Old Apr 27, 2017 | 09:05 PM
bbarbulo's Avatar
flux paste it first. that area would be exposed to air and would have a layer of oxide on top. need to use flux paste to clean it off and etch the copper for soldering
8bluddyknuklz
Jan 25, 2010 12:30 PM
ej6hatchie
Mar 4, 2008 10:38 AM
ronintegra
Jan 3, 2006 12:10 PM
diko
Jul 17, 2004 03:22 PM
-Bionic-
Apr 25, 2004 06:44 AM
