Wire Harness Help
I have a 93 Si VTEC. I need to figure out what the wire harness i need is called so I can perhaps find one. I'm looking for the wire harness that the main engine harness plugs in to at the passenger side shock tower. To be technical, its the harness that plugs into connectors c135 and c136 that i'm in search of. So its the harness that goes through the firewall on the passenger side and connects to the main engine harness. What harness is this? What does it connect to in the cabin? Just straight to the ECU?
Thanks!
Thanks!
EVERYWHERE !!! Fuse box, dash harness, engine harness, through the firewall to the drivers side and passenger side shock towers, to the center tunnel, to the rear sub harness, to both door jams, and the left kick panel to meet the sunroof/dome light sub harness... shall I continue ?!? LOL
Yea the cabin harness is a nightmare. I wanted to separate the cabin harness from the ECU but its a huge project, it was easier just to pull the cabin harness connections from the engine bay thru the firewall.
Do you have an issue your trying to resolve?
