Engine harness question
I'm trying to find a part of the engine harness I have the main one that connects to everything on the engine I just need the one on the passenger side that's 3 plugs that goes into the firewall that connects to the fuse box and ecu does anyone know what that part of the harness is called?
Re: Engine harness question
It's the harness that plugs into the main wire harness on the passenger side it has 3 plugs then it goes to the fuse box, ecu and I'm not for sure what else. I'm just trying to find out the correct name because when I look for a wire harness all I find is the main wire harness that plugs into everything o n the motor
You need illustration #1?.... i would go to the junkyard and ****** what you need or post a WTB ad in the hondamarketplace as they are over 700 at majestic honda NEW!
coupedragracing
08-07-2011 06:36 PM
AWD: Jeff
08-13-2007 10:14 AM
