obd2b-obd1 ecu harness problems
Old Apr 18, 2017 | 11:38 AM
710times's Avatar
Icon6 obd2b-obd1 ecu harness problems
So as stated in the title im having the one issue that most people have when it comes to these harnesses. Well this is where my problem begins, so as most threads say online to take the spare terminal on the icm and and run a wire to the shock tower tach plug. as soon as i hook up the wire to the lonely blue tach wire on the tower it shuts off. if the car is running and i touch it to the blue tach wire the car shuts off. as soon as the wire is removed is starts up. its on the right terminal in the dizzy, everything is ran how its suppose to. i have 2 different obd1 ecus also both have the same return when used, there is no difference at all still no tach and as soon as the connection is made the car dies. this is in a 2000 civic ex coupe. any help would be great. thank you
710times
Apr 20, 2017 09:39 AM
radicaled434
20
Jun 4, 2015 04:27 AM
808jdm_profileEG6
Aug 6, 2009 02:29 AM
Rich Pedraza Jr
Jul 30, 2009 06:18 AM
esean93
Aug 23, 2008 10:33 AM
