1995 accord missing when driving
i have a 1995 accord f22b1 vtec and when driving it at lower rpms it has a dead miss and sputters. was told it has new distributor, plugs, and wires when i bought it. What could be causing this?
Check the valves are adjusted correctly. Should check them every 30Kmiles. If they are too tight the valves will not properly seat and seal when the engine warms up. Loss of compression will cause a miss.
its fixed and running better than it ever has now. i cleaned the entire egr system and that seemed to cure it. all the egr stuff was completely clogged up with carbon. the car has 300,000 miles and i doubt that its ever been cleaned out before. but it runs strong now.
jerhigdem
May 5, 2016 07:56 PM
