1990 Civic engine issues - Ignition?
Old Apr 17, 2017 | 12:33 PM
MaverickSawyer's Avatar
Icon5 1990 Civic engine issues - Ignition?
Was driving to school today on the freeway when the "Check Engine" light comes on, the engine starts to buck and skip, and I immediately take the next exit in neutral and coast to a safe spot. Pop the hood, check all my spark plug wires, and make sure they're seated on the distributor. Try to fire it up again, and it cranks for a few seconds, catches briefly, then sputters out.
Car has 261k+ miles on it, but the distributor was replaced in 2011 after it disintegrated on me... on the freeway.
Car had a fresh tank of gas, battery is fine, alternator's going out, but not gone yet. Need to swap it soon, though.
Should I check the distributor first, or should I look at some other component of the engine?
Old Apr 20, 2017 | 05:52 AM
jlicrx's Avatar
Default Re: 1990 Civic engine issues - Ignition?
did you check the codes on the ECU?
Old Apr 23, 2017 | 09:18 PM
Honestly, I haven't had an opportunity yet, and the engine has run fine when cold twice since the incident. Would the codes still be logged in the ECU?
Old Apr 24, 2017 | 05:58 AM
jlicrx's Avatar
yes, the codes stay in the ECU until it is reset by removing power to it
darrinirox
11
Nov 10, 2012 05:07 PM
93 DET
Feb 14, 2012 12:36 PM
93R33Lude
Mar 2, 2004 05:48 PM
serious
14
Mar 31, 2003 05:46 PM
