NY: TURBO D16 PARTS - PISTONS/RODS/MOUNTS/TRANS/COOLING/SUSPENSION/OEM - LIQUIDATION!
EMAIL IS THE BEST CONTACT METHOD:SJOYCE14@GMAIL.COM
I have stack of used parts and a few BNIB parts
**Please respect my time and not bother me with photo requests for a brand new OEM rear main seal, etc**
**ALL PRICES ARE OBO**
- Shipping and Paypal fees will be negotiated upon sale.
- Discounts for multiple items.
USED PARTS:
**ALL PARTS HAVE APPROX 2000 MILES UNLESS OTHERWISE NOTED, THIS CAR WAS BUILT IN ONE SHOT!!**
Engine:
- ARP HEAD STUDS: $50
- Bottom End:
- D16Z6 75.5 CP Pistons 9:1 Compression with Scat H Beam Rods and ARP 2000 Bolts: $600
- I Believe these can be used with other D - Series Engines, do your homework.
- One Piston was replaced with a brand new in box unit that's included in the sale. I damaged one during disassembly, long story.
- I cleaned up one piston just to show their overall condition.
- The pistons DO have light scratching and show signs of use. They are NOT in perfect condition.
- D16 S20 Transmission with FULL Synchrotech Carbon Master Rebuild Kit: $300
- Brass Synchros with Carbon Lining with all OEM Bearings and Seals SHIFTS PERFECT - Competition Stage 4 Clutch: $250
- Competition Ultra Lightweight Flywheel 8.8 Lbs: $150
Cooling:
- Mishimoto Radiator with Shroud and Fan: also includes NSX Rad Cap: $200
Suspension/Chassis:
- Hasport Engine Mounts P/N: DCSTK Race 70A: $200
- These just need a nice metal polish to look new again.
- Skunk2 Rear LCA's: $75 - New bushings needed.
- Suspension Techniques 25mm Front and 19mm Rear Sway Bars: $250 (prefer selling as a pair)
- Chassis Mounted Front Splitter for EG:$200
MISC:
BRAND NEW IN BOX PARTS:
Engine:
- OEM D16Z6 Head Gasket (BNIB): $50
- Misc OEM D16Z6 Gaskets and Seals, Valve Cover, Rear Main, Oil, etc. The part numbers are shown below, I'd rather not separate this stuff $50 takes the whole lot.
Brakes:
- Power Stop K699 Brake Kit: Front Cross/Slotted Rotors and Pads (BNIB): $75
- Dorman Brake Master Cylinder: $20
Bushings/Wheel Studs/Bearings:
- Energy Suspension Bushings:
- Front Control Arm 16.3105R Kit: $30
- Front Shock Kit 16.8102R Kit: $15
- Rack and Pinion 16.10102R Kit: $10
- Moog Lower Ball Joints Pair: $40
