my 99 accord distributor is moving
Old Apr 13, 2017 | 08:40 PM
warfield21's Avatar
Default my 99 accord distributor is moving
my distributor is moving when I try to start my car what would make it do that it is as tight as it will go and my car won't start
Old Apr 13, 2017 | 09:06 PM
holmesnmanny's Avatar
Default Re: my 99 accord distributor is moving
try tightening it down
Old Apr 14, 2017 | 04:29 AM
jollyhonda's Avatar
Can you move the distributor by hand?
Old Apr 14, 2017 | 08:03 AM
warfield21's Avatar
it is as tight as it will go and I don't think I can move by hand I will go see
Old Apr 14, 2017 | 09:23 AM
jollyhonda's Avatar
So what makes you think it is moving if it is tightened down and you can't move it by hand?
Old Apr 14, 2017 | 10:37 AM
warfield21's Avatar
because I have watched it move up and down when my friend try to start my car and you can't move it with your hand but when you try to start it it starts moving when its trying to crank
Old Apr 14, 2017 | 05:43 PM
jollyhonda's Avatar
That is a pretty good sign...is it rotating I guess? Is it properly seated into the end of the cam? Are all 3 hold down bolts tight? Sounds like a funky issue you are having.
Old Apr 16, 2017 | 03:24 PM
warfield21's Avatar
I only have two holes for it to be tighten down I can't figure out
vaderman_x
Jun 9, 2019 07:00 AM
ratchetEDsedan
14
May 30, 2017 07:08 PM
movingIIshadow
Jun 17, 2006 09:43 AM
jsou
Jul 5, 2005 02:26 PM
