EG6 exhaust
Old Apr 13, 2017 | 06:29 PM
MitchHamilton's Avatar
Default EG6 exhaust
Just wondering if this magnaflow high flow cat will bolt up to my eg6, I have a stock manifold and bought a yonaka cat back, wanted something better but I didn't have the money at the time. The exhaust matches up with the stock cat but I just wanna be sure before I spend money on the magnaflow. Thanks guys
Exhaust http://www.garage16.ca/yonaka/yonaka-catbacks-stainless/ymcb004/i-2196569.aspx
cat http://www.garage16.ca/magnaflow/magnaflow-catalytic-converter-directfit/22635/i-156912.aspx
Old Apr 14, 2017 | 09:08 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: EG6 exhaust
Should be fine.
I have the yonaka cat back bolted up to my after market high flow cat.
The 3 bolt flange outside dimensions appear to be standard. Where it changes is the bore diameter depending on the size/type of catalytic converter. Stock uses a smaller pipe than the high flow variants.
Old Apr 14, 2017 | 01:33 PM
Right on man thanks a lot. Do you know if I can just go to my local parts store and pick up a spring bolts kit for any 92-95 civic to mount it?
Old Apr 14, 2017 | 04:07 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Yes you can, it won't be the exact same design as the OEM spring bolts for the front of the catalytic converter but they do work just fine.
I've collected a few from the junk yards when they cut the cat out leaving the bolts and flanges in place.
dxg4
Jul 21, 2009 05:26 AM
loner714
Mar 18, 2007 05:36 PM
Krayzielix
Mar 20, 2003 09:09 PM
ShiftDown
Aug 6, 2002 02:36 PM
LuderCriS
Mar 15, 2002 04:44 AM
