Integra
Old Apr 13, 2017 | 12:41 PM
Aramirez15942's Avatar
Default Integra
Why does my integra with a b20 swap 5 speed, run alot faster when its cold? is it the extra fuel that helps? or maybe the person who did the swap didn't tune it for the 2.0 fuel maps?
Old Apr 13, 2017 | 02:40 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: Integra
normal, basic equation is cooler air charge = more hp
usually the engine runs a bit faster when either engine is cold which is not recommended for example on a vtec motor vtec wont engage until ecu reads engine is at op temp. Or on a very cold night you will experience the engine runs a bit fast hence the colder air charge that gives more fuel and timing added from the ecu.
Old Apr 13, 2017 | 07:05 PM
trm4life's Avatar
Default Re: Integra
Exactly. In the winter time ANY car will get worse gas mileage because it needs more fuel for ignition. Hence active forced cold air intakes actually add power. (putting a cold air filter under your hood without cold air actively getting to it, will not add power because of under hood temps) However, in any owners manual, it will tell you not to drive aggressive on a cold engine.
Greyhead
Honda CR-V & Element
Mar 18, 2014 05:35 PM
MooreBoost
Aug 31, 2008 05:52 AM
bopbop93030
Mar 13, 2008 05:48 PM
Benjithx
Jan 13, 2005 10:08 AM
wasdayuca
Jan 12, 2005 08:36 AM
